Topaz2008 0 Posted March 11, 2009 Having suffered from a flat battery on more than one occasion I decided to try and get to the bottom of it. I placed a meter in line with the battery and measured 0.6A load with everthing off. Is this about right or do I have an electrical issue? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted March 11, 2009 That's high. The only original Corrado item that draws currently constantly is the clock in the MFA. Stereo memory and Alarm current draw etc are the likely culprits and not forgetting of course, our old friend the boot light. Check the light isn't staying on when you close the boot. As it 0.6A will drain a 56ah battery in about 3.5 to 4 days. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted March 11, 2009 Yowser, 0.6A is a lot. Most Corrados seem to pull about 0.05 - 0.09 A constantly, killing the battery in about three weeks. Love to know what causes that. Can't just be the clock ... Quote Share this post Link to post Share on other sites
Topaz2008 0 Posted March 12, 2009 I will have to carry out further investigations. The car is fitted with a toad alarm / immobilizer system and a normal Sony CD multi changer (non of that fancy ICE big amps etc) apart from that the wiring is standard. Thinking about it the boot may have been ajar, so the boot light may have been on. The cars in store at the moment so I will investigate further next time I am down there. Quote Share this post Link to post Share on other sites
sparks 0 Posted March 13, 2009 its that or start pulling out fuses till the current drain goes !! Quote Share this post Link to post Share on other sites
Topaz2008 0 Posted April 29, 2009 Been working on the car today and did a test (this time with the boot shut!). 40ma with everything off. Seams low to me what do you all think? Quote Share this post Link to post Share on other sites
dr_mat 0 Posted April 29, 2009 Been working on the car today and did a test (this time with the boot shut!). 40ma with everything off. Seams low to me what do you all think? 40ma will drain your battery in about 2 months, so that's not a lot at all, no. Quote Share this post Link to post Share on other sites
Topaz2008 0 Posted April 30, 2009 :D thats good another job off the list Quote Share this post Link to post Share on other sites
dr_mat 0 Posted April 30, 2009 What did you change? What was causing the drain? Boot light?? Quote Share this post Link to post Share on other sites
Topaz2008 0 Posted April 30, 2009 Yes it was the boot light I had shut the boot but the latch had not clicked shut. It was the last job of the day and I was probably in a hurry. Quote Share this post Link to post Share on other sites
