StormchargedVR6
Performance Calculator
Mine 8)
Power at Flywheel (BHP) : 401
Weight without Driver (KG) : 1350
Power to Weight Ratio (BHP Per Ton) : 301.81
0 - 60 (Secs) : 4.39
0 - 100 (Secs) : 9.29
60 - 100 (Secs) : 4.90
Quarter Mile (Secs) : 12.59
Terminal Speed (MPH) : 116.39
Drag Strip Quarter Mile (Secs) : 12.39
Drag Strip Terminal Speed (MPH) : 118
Lol! Fun toy this....
Power at Flywheel (BHP) : 291
Power to Weight Ratio (BHP Per Ton) : 219.02
0 - 60 (Secs) : 5.30
0 - 100 (Secs) : 12.21
60 - 100 (Secs) : 6.91
Quarter Mile (Secs) : 13.61
Terminal Speed (MPH) : 105.55
Drag Strip Quarter Mile (Secs) : 13.41
Drag Strip Terminal Speed (MPH) : 107.45
Lots of factors that can change how real these figure are though...... Your diff will be a huge benefit as would some sticky tyres (R888's spring to mind)
Trying different weight figures highlights just how much difference a few kilos makes to performance.
Having said that, it seems pretty accurate 0-60, but the quarter mile figure is a little optimistic. Mine will do low 14's, but never had a 13 :lol:
The weight of vr6 without driver is 1240 kg afaik
But I used same weight like you guys. Because I cant see why to use kerb weight without driver for drag times.
I dont know yet what the power of mine car is,then I used times from the pod with this result
Power at Flywheel (BHP) : 228
Power to Weight Ratio (BHP Per Ton) : 171.60
0 - 60 (Secs) : 6.37
0 - 100 (Secs) : 15.84
60 - 100 (Secs) : 9.47
Quarter Mile (Secs) : 14.74
Terminal Speed (MPH) : 96.48
Drag Strip Quarter Mile (Secs) : 14.54
Drag Strip Terminal Speed (MPH) : 98.16
Not a bad tool, it is almost spot on with the figures for my Vauxhall-engined Mini :)
It won't even calculate it for an 8V Rado though as the power-to-weight ratio isn't high enough! :lol: - edit - I tell a lie, it does work but the figures aren't worth posting up :brickwall:
That program is so non-specific it's laughable! I'd take any of those results with some of this:
yeah, that's salt.
I know this, i put mine higher because of extra weight of Charger cooler, bass box, etc ,etc.
Be even quicker if i binned this lot :lol:
I think its pretty accurate. Because I put 190 hp and weight with driver 1350 kg and im getting same times when i took my stock rado first time to the pod
Power at Flywheel (BHP) : 300
Power to Weight Ratio (BHP Per Ton) : 225.79
0 - 60 (Secs) : 5.19
0 - 100 (Secs) : 11.86
60 - 100 (Secs) : 6.67
Quarter Mile (Secs) : 13.49
Terminal Speed (MPH) : 106.64
Drag Strip Quarter Mile (Secs) : 13.29
Drag Strip Terminal Speed (MPH) : 108.56
Yeah Monkey, we're gonna come round there and make you eat that salt of yours! :lol:
Er, frankly I'd be happy if my engine was putting out 160 still so here are my figures:
Power at Flywheel (BHP) : 160
Power to Weight Ratio (BHP Per Ton) : 120.42
0 - 60 (Secs) : 8.69
0 - 100 (Secs) : 25.19
60 - 100 (Secs) : 16.50
Quarter Mile (Secs) : 17.13
Terminal Speed (MPH) : 82.46
Drag Strip Quarter Mile (Secs) : 16.93
Drag Strip Terminal Speed (MPH) : 83.83
I don't really know how much a G60 weighs. I just copied Junkie. :lol:
Revised equation results :lol:
Weight without Driver (KG) : 1200
Power to Weight Ratio (BHP Per Ton) : 254.01
0 - 60 (Secs) : 4.85
0 - 100 (Secs) : 11.06
60 - 100 (Secs) : 6.21
Quarter Mile (Secs) : 13.15
Terminal Speed (MPH) : 109.05
Drag Strip Quarter Mile (Secs) : 12.95
Drag Strip Terminal Speed (MPH) : 111.04
You eat more pies than me Junkie. :lol:
Revised equation for standard G60:
Weight without Driver (KG) : 1175
Power to Weight Ratio (BHP Per Ton) : 138.36
0 - 60 (Secs) : 7.69
0 - 100 (Secs) : 21.29
60 - 100 (Secs) : 13.60
Quarter Mile (Secs) : 16.13
Terminal Speed (MPH) : 87.03
Drag Strip Quarter Mile (Secs) : 15.93
Drag Strip Terminal Speed (MPH) : 88.52
That's more like it. 8)
Im just been realistic hedgehog.
Those weights will be with no fuel i bet, im running 1/4 of a tank :wink:
Yeah, I'll give you that one. So we need a fuel factor and a pie factor adding. :lol:
