Thom 1 Posted March 23, 2009 Yo yo, I have an oil leak which looks like it's originating from somewhere between the sump and filter housing. I have routinely changed the filter since it started so that's ok, also checked the pressure senders and they seem fine too. The leak becomes a lot worse when the engine's running and slows down once off. I will get under there and have a proper look asap, but anyone have any ideas? Thanks :? Quote Share this post Link to post Share on other sites
gcorrado 0 Posted March 24, 2009 Try checking the brown oil sensor Quote Share this post Link to post Share on other sites
neil w 0 Posted March 24, 2009 The metal gasket that goes between the filter housing and the block has a rubber bead on it which breaks down and allows oil to leak Quote Share this post Link to post Share on other sites
horney 0 Posted March 25, 2009 I had to change the gasket between the oil cooler and the bracket that it screws up onto. Quote Share this post Link to post Share on other sites
