woody
VR6 Sounds Like a Air Leak Of Some Sort
Driving my VR6 to work this morning I heard a some kind of air leak. As I changed up gear , dipped the clutch the hissing noise went away but as soon as I let the clutch go back in it came back again.
Any Ideas anyone of where to look
thanks
Woody
If you can't hear it at idle in the engine bay but could hear it while moving, I think it might be something other than an air leak. However, it could be a part moving under load creating the hole! Common places are the large plastic air intake elbow that runs from the MAF sensor to the back of the block (lots of junctions to break) and the Idle Pot Damper Valve.
I found mine by moving parts around while it was idling and seeing what hissed!
Good luck,
Tom
