Slimg60
Cooling system not pressurising
I've noticed recently that the cooling system isn't pressurising. If I gently squeeze the the top hose from the rad I can hear a "gasping/gurgle" from the expantion tank, it's coming from the small square holes on the side, under the plastic cover. It's a new bottle with a new blue cap too so I'm puzzled as to what is going on. Temp seems fine, running about 90, if a little cooler sometimes. Oil has been a bit warmer than normal recently too, but I'm fitting a mocal to combat this.
Any ideas whats causing?? :shrug:
Cheers
Slim
