roccostevo 0 Posted May 3, 2009 Hi guys nube here just bought my first corrado, and love it. The problem is the clutch peddal at times wont come back up.So i have to keep puttind my toe under it to pull it back up.But if i put the clutch down and put it into first gear and keep the clutch in for a minute or too the clutch still bites at the same point. Dose this mean ti is not the master cylinder. Is there a way of checking the master and slave cylender sepeterly. Thanks Steve :confused4: Quote Share this post Link to post Share on other sites
dirtytorque 0 Posted May 3, 2009 Hi steve Welcome. Do a search under clutch pedal won't return.Common fault with the Corrado hydraulics. Cheers. :) Quote Share this post Link to post Share on other sites
Richie_t 0 Posted May 9, 2009 Give the clutch a bleed, just like brakes they need the fluid changing every few years, this is the cheapest fix you can try really unless the return spring has come off, in my experence 99% of the try its hydrualic. Good luck Quote Share this post Link to post Share on other sites
