Mullet52
Lambda problem?
Hi all. 1st post on here after someone recomended me to here(Greeny)
I have a mk2 golf with a G60 engine out of a rado. It started running crap all of a sudden. It had a new blue and black temp sensor so I knew it wasnt that. So I taped the WOT switch up and now its running fine again. So does this mean I need a new lambda?
Thanks all
You taped the WOT switch which way? Open or closed?
Could be the lambda I suppose, if a G60 has one. If the ECU was on WOT mode all the time I'd expect it to run very strangely though ..
Taped it closed, so the ECU reads its on WOT all the time
It idles a bit higher than usual(1200rpm), but it runs fine
That's weird. Still, on WOT mode it's ignoring the lambda. It'll probably be running quite rich though.
