NeilG60 0 Posted May 15, 2009 Im looking at having all the belts/pulleys/tensioners replaced on my G60, basically due to them not being done at the last cam belt change!! Im after a full list of the required parts, with VAG part numbers if possible..... Obviously im aware of there being 2/3 belts but access isnt ideal and I cant see exactly whats what! :shrug: Quote Share this post Link to post Share on other sites
VEEDUBHEV 0 Posted May 15, 2009 Your best bet is to phone your local vdub dealer and they will be able to give you the part numbers with no obligation to buy from them. Although you will probebly find that will be the route you'll have to go down! Hope this helps. Hev Quote Share this post Link to post Share on other sites
Neil VR6 0 Posted May 15, 2009 As the car's new to your I'd take it to a specialist for a once over to make sure your spending your money where it's needed most. Whereabouts in the country are you based? Quote Share this post Link to post Share on other sites
NeilG60 0 Posted May 15, 2009 As the car's new to your I'd take it to a specialist for a once over to make sure your spending your money where it's needed most. Whereabouts in the country are you based? I appreciate your advise, but the car has already spent time at a tuning company for minor pre-mot works!! Its certainly where my money needs to be spent at the minute! :D Im based in Norwich by the way!! I use APT (Lenwade, Norwich) for all of my work normally but im having someone else fit the belts etc so I want to do the leg work in getting the bits before hand!! I can speak to TPS (local Vag parts distributor) but just hoped I could go armed with the right numbers etc as I have had problems with parts distributors before !! Quote Share this post Link to post Share on other sites
NeilG60 0 Posted May 15, 2009 Your best bet is to phone your local vdub dealer and they will be able to give you the part numbers with no obligation to buy from them. Although you will probebly find that will be the route you'll have to go down! Hope this helps. Hev That is on the cards, but really wanted to go armed with what I want!! :D Quote Share this post Link to post Share on other sites
