simon_miles 0 Posted June 1, 2009 I've had my VR for about a month now and I noticed something peculiar, when accelerating in the lower rev range 200 - 400 there is sometimes a very small but noticeable stutter (like the engine pulls then pauses for a millisecond then continues pulling again). Not sure if this is related but a couple of times I have trouble stating her, she turns over fine then just cut out and you can start her again get the revs high but then she still cuts out. Any idea chaps? Quote Share this post Link to post Share on other sites
blitz877 0 Posted June 1, 2009 the cutting out could be the icv mate Quote Share this post Link to post Share on other sites
dr_mat 0 Posted June 1, 2009 The cutting out could also be the immobiliser if you have a late VR. Not sure what you're doing driving in the 200-400 rpm range though, so I'm going to assume you really mean 2000-4000 rpm .. ;) So. Check the basics. Plugs, leads, coil pack/distributor. Get the error codes read from the ECU, see if that's throwing anything up. Quote Share this post Link to post Share on other sites
simon_miles 0 Posted June 2, 2009 Thats great guys thanks, Can I check the ECU myself? Quote Share this post Link to post Share on other sites
