MaverickG60
Good brake upgrade for a '92 G60...
Hi guys,
As in the title, i'm after some advice and guidance on what is the best way about upgrading my standard G60 brakes.
Absolutely anything considered, maybe someone could answer this... if able to, i'd like to put Porsche Boxster callipers on?
Many thanks :)
The Brembo setup from a Seat Ibiza Cupra is a fairly straight bolt on kit and you just need some custom hoses that Badger5 supply. You will need to make sure they fit under your wheels though!
If you are still running standard wheels then just fit black diamond discs and Ferodo DS2500 pads.
