Macca88 0 Posted June 9, 2009 earlier on this year my clutch went which i could understand because its an old corrado (1990). But now it sounds like the bearings are going again.......is it the s**t service and fitting or the actual standard clutch fitted............ Quote Share this post Link to post Share on other sites
Jim 1 Posted June 9, 2009 Clutches on the Corrado are pretty darn solid and should last well over 100k - so I'd suspect it might either be the clutch you're fitting not being up to the job or the guy who's doing it that's not doing it right! Do you know if he's using a genuine VW clutch? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted June 9, 2009 And did they use the correct grease on the release bearing... Take it back to the garage, as Jim said Corrado clutches last ages and ages. Quote Share this post Link to post Share on other sites
jamin 0 Posted June 9, 2009 Anyone know how much it is to get the clutch replaced on a VR6? Mine makes a slight whine when I pull away quickly (but doesn't appear to slip), is it the thrust bearing thats gone? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted June 9, 2009 But now it sounds like the bearings are going again....... Is it A) worse when hot and B) only noticable when your foot is off the clutch pedal? If Yes to both, that is more than likely the layshaft pinion bearing. Very common and nothing to worry about. If the noise only happens whilst pressing the clutch, that is definitely the release bearing. Anyone know how much it is to get the clutch replaced on a VR6? Mine makes a slight whine when I pull away quickly (but doesn't appear to slip), is it the thrust bearing thats gone? 4 hours labour + clutch (£100) usually. If the clutch isn't slipping or juddering, live with it. Again, it's not important. Quote Share this post Link to post Share on other sites
jamin 0 Posted June 9, 2009 Anyone know how much it is to get the clutch replaced on a VR6? Mine makes a slight whine when I pull away quickly (but doesn't appear to slip), is it the thrust bearing thats gone? 4 hours labour + clutch (£100) usually. If the clutch isn't slipping or juddering, live with it. Again, it's not important. Ok thanks, the noise can be quite annoying though, and a little embarassing at times. Quote Share this post Link to post Share on other sites
