__Andy__
heated rear screen fuse keeps blowing...
ok guys, i replaced the fuse this week, switched it on once it worked for a bit and then the fuse blew... i replaced the fuse again today and tryed a differnt switch and it blew instantly.. please note ive used fuse's from my spare fuse box so were not brand new..
im stumped as to why it keeps blowing the fuse so was hoping someone would be able to point me in the right direction...
any help will be greatly appreciated.
If it blows instantly it will be a dead short...
Most likely corrosion on one of the wing mirrors
on the wing mirror glass? my glass is near perfect... what bit do you think could be corroded?
The glass is perfect because the heating elements aren't working :D
Prise them off and have a look at the connectors behind
well my drivers side mirror works but doesnt, basically its int but not fully, i think the mounting for it may be slightly broken... its never been a problem and has only just happened that the fuses are blowing...
