klara
power steering rack from VR6 would it fit in 16V???
hello everyone!!
i have 16V 1.8l corrado and i need power steering rack. will rack from VR6 2.9l fit in my car?
please help :?
I fitted the ZF rack off a Vr on my G60 a while back.
Your gonna need to also change the PS pump to the VR's ZF type,you'll need the feed and suction pipes changed to the VR's.
You'll need to change the steering universal joint near the pedals to the 22 spline later versionfitted to '91/'92 corrados.
Your also gonna have to change over the steering arms in place of the longer VR versions,the earlier versions bolt into the VR
rack ok but the threaded portion of the early rack arms is a bit short,just locktite them in as i did.
I found that the quality of the ZF rack compared to the TRW jobbie fitted to my G60 was much better,so was
the steering 'feel'.
Remember also that if you have lowered your car and are running 205/50/15 rubber the tyres will rub on the car frame.
