Timbo 0 Posted July 2, 2009 I'm getting pretty sick of my ABS being intermittent, so I've resolved to replace the pump to see if this sorts it. I've read all kinds of conflicting information about bleeding the brake system when it has been drained ranging from not needing VAG COM at all to some elaborate procedure involving pressing the brake pedal ten times and opening the front caliper bleed nipples in sequence :scratch:. The "best"/most convincing procedure I've come across goes something like: 1. Bleed RR, RL, FR, FL, ABS bleed valves, master cylinder. 2. Start VAG COM, run the bleed procedure. 3. Repeat step 1. 4. If still spongy, goto step 2 and continue. Does this sound sensible to anyone that's actually done it? TIA. Quote Share this post Link to post Share on other sites
RW1 0 Posted July 2, 2009 The right hand drive brake system (Teves 04) does not use VAGCOM. Using VAGCOM and procedures relates to LHD Corrados. Only step one can be done. Quote Share this post Link to post Share on other sites
Timbo 0 Posted July 3, 2009 Ahhhhh, OK. That explains a lot actually. Cheers. Quote Share this post Link to post Share on other sites
