andycowuk 0 Posted July 15, 2009 hi all! I stupidly forgot to disconnect the throttle pos ssensor when i was taking the engine out, and strangely enough the wires didn't impede the engine hoist! :epicfail: I've got new ends to put into the plug, but i need to know the order to put them in. Can someone please advise? TIA Andrew Quote Share this post Link to post Share on other sites
andycowuk 0 Posted July 17, 2009 Anyone with either a g60 they can check the order of the wires in the plug behind the throttle body, or someone with the Bentley manual able to help out here? Its the last thing I need to do under the bonnet before its back on the road again! TIA Andrew Quote Share this post Link to post Share on other sites
waynos 0 Posted July 17, 2009 got my old g60 loom in front of me,if you look at the connecter with the pins facing you there is a red (blue trace) on the left,brown (white trace) in the middle, and blue (black trace on the right) hope that helps dude Quote Share this post Link to post Share on other sites
andycowuk 0 Posted July 17, 2009 Thanks mate thats brilliant - although if i hold it upside down from you i'll get the left and right mixed up If you peel back the rubber cover the pins are numbered - either that or just tell me if the notches on the inside were up or down. Really appreciate your help :cheers: A edit to make this useful for future: Key words: G60 wire loom harness tps throttle position sensor pot connector plug just had a look now mate pin 1 - red (blue trace) pin2 - brown (white trace) pin 3 - blue (black trace) Quote Share this post Link to post Share on other sites
