funboxvr6
VAG-COM Ache
Hi All
I'm using VAG-COM 409-1 and an USB lead (bought from Eshrules). All used to work and scan fine. Now I'm geting the 'Communication Error' as documented elsewhere when trying to connect to the ABS module.
I've updated the driver (to one with a latency option) & changed the Latency Timer to 5 (as also suggested elsewhere on here), tried it on 2 Corrados with no joy.
I've tried it on my mate's Golf and it works fine.
Can anybody help please?
Could it be drivers & if so can anyone point me in the direction of known working drivers so at least I can eliminate that?
All help, advise & suggestions gratefully received.
Go to control panel and select the com port part and go to properties. Under there is a 'Latency' setting which maybe set to something like 16. Try setting it lower. I set mine to 5 and it worked fine, though yours may require a different value.
Oh sorry, dunno how i missed that you'd done that.
I would have thought that would have fixed it... that solved the issue with me. Though i wasnt using version 409.1, i used 308.11 (id have to double check that).
