machine 0 Posted July 22, 2009 Hi all. Looking for a bit of help if possible? What pipes go to A, B, C and D on my G60 rail? I've done it this way but have no idea if it's correct: A = Main Fuel Feed Pipe B = Blocked this off C = Small tube to the inlet D = Return Fuel Pipe Can anyone tell me if this is correct or wrong? if wrong whats the correct way? Any pics? Thanks alot :D Quote Share this post Link to post Share on other sites
Supercharged 2 Posted July 22, 2009 Ok, 1 out of 4 :) A = Goes to the after-run pressure switch via a small hose B = is the Main feed in from the black pipe C = Goes to the Inlet manifold (this vac pipe controls fuel pressure) D = Goes to the blue return from the FPR Assume this is an engine conversion but if you can I would recommend using new pipes (and clips) from VW as these a shaped and last ages compared to bog standard pipe. Quote Share this post Link to post Share on other sites
machine 0 Posted July 22, 2009 Excellent, I wasnt too far off then haha. I have a Mk1 Golf GTi which the fuel rail is fitted to but i'm also after buying a Corrado G60 or VR6 in the next few months. Incase your wondering why i've fitted a G60 rail to a Mk1 GTi 1.9 8v? well the reason is because it is to be turbo charged and i have fitted an Emerald K3 ECU for the 3 map settings. :D I decided to check the fuel supply because when i try to start the car it is backfiring. I'm guessing this is down to either fueling or timing? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted July 23, 2009 I decided to check the fuel supply because when i try to start the car it is backfiring. I'm guessing this is down to either fueling or timing? Probably down to no fuel pressure regulation if you have C blocked off... you need to take a feed from the inlet manifolf or the pipe that goes to the brake servo (if fitted) Quote Share this post Link to post Share on other sites
