Richardshoes 0 Posted July 27, 2009 Hi, I am thinking about this RSR outlet and wondered - Does anyone have any data to prove the difference this makes as a replacement for the silencer box? Some figures or graphs proving a quicker boost build up would be great. Cheers. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted July 27, 2009 I think the main point of these is that they don't leak like the silencer box which are notorious for it. Also can be ported to match the charger outlet. Quote Share this post Link to post Share on other sites
Richardshoes 0 Posted July 27, 2009 BBM claim it does all this? Now includes CNC machined knife edged ribs. The first and original RSR billet g-lader outlet kit. The BBM RSR outlet has far less back pressure restriction than the Rallye Golf adapter outlet. Increases boost pressure with a quicker boost build rate. A solid torque and power increase from the very low rpm's to redline. Sharper throttle response without the damping effect of the factory silencer box. Crisper G-Lader sound, minimizes droning without additional interior noise. A direct replacement for the leak-prone plastic silencer box outlet. Complete kit bolts onto any G60 G-Lader without modifications. CNC machined billet from 6061-T6 aluminum for a perfect fit. Optional port-matched G-Lader outlet housing, please see RS/RSR outlet outlet porting option link below. Is the G-WERKS unit the same? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted July 27, 2009 Ah ok - I was just talking about the original VAG part... Yeah the BBM ones is meant to be better in terms of performance - assume G-werks can supply as they are a BBM dealer. Quote Share this post Link to post Share on other sites
sparks 0 Posted July 28, 2009 bascially the plastic box flexed so lost pressure in the box the bbm didnt plus all the stuff off the web site aswell cheers stu.. Quote Share this post Link to post Share on other sites
Richardshoes 0 Posted July 28, 2009 Got one. A type of airfoil has been machined into the two fins. The leading edge is more or less a knife edge, as is the back. This should reduce turbulence somewhat and create a more laminar flow, bringing the reynoulds number down through this stage. Does anyone know the displacement for 1 revolution of the G-charger? What is the efficiency like in terms of boosting the displaced air to a higher pressure? A nicely machined unit. Will install this weekend and see if I can note any difference. Quote Share this post Link to post Share on other sites
Richardshoes 0 Posted July 29, 2009 Here is a screenshot of some analysis. Red indicates increased velocity. The parameters are wrong, as I still don't know the output flow from the G-charger? :? Quote Share this post Link to post Share on other sites
Richardshoes 0 Posted August 3, 2009 Got it installed. Seems a little louder and perhaps marginally more responsive. Plan to monitor boost levels at varying locations along the boost path, The route seems rigorous and I expect there is a significant loss involved in flowing from the charger down through the small air/air intercooler then up into the throttle body, through that and into the inlet manifold. Quote Share this post Link to post Share on other sites
Richardshoes 0 Posted August 26, 2009 Got some info 860cm^3 per/rev rated speed = 10000RPM Quote Share this post Link to post Share on other sites
S73DOD 0 Posted September 18, 2009 Hello,ive been tyring to get an RSR Outlet kit for my g60 as the standard silencer box has cracked. ive phoned jabba,they carnt get any and g-werks said they are gettin some in a couple of weeks which they told me a couple of weeks ago.is there anywere else in the uk that sell these kits.thanks. :help: Quote Share this post Link to post Share on other sites
eddy.h 0 Posted September 18, 2009 Hello,ive been tyring to get an RSR Outlet kit for my g60 as the standard silencer box has cracked. ive phoned jabba,they carnt get any and g-werks said they are gettin some in a couple of weeks which they told me a couple of weeks ago.is there anywere else in the uk that sell these kits.thanks. :help: i fitted a rsr outlet got from g-werks they said the same it tuck 3 months http://www.maddoggsyndicate.com Quote Share this post Link to post Share on other sites
S73DOD 0 Posted October 26, 2009 My rsr outlet kit should arrive tomorrow,YAY.ive seen youre vids eddy,it sounds good mine sounds like a hovercraft at the mo with that cracked silencer box. Quote Share this post Link to post Share on other sites
eddy.h 0 Posted October 27, 2009 My rsr outlet kit should arrive tomorrow,YAY.ive seen youre vids eddy,it sounds good mine sounds like a hovercraft at the mo with that cracked silencer box. thanks mate think of all the boot you will have :clap: how long has it took did you order from g-werks Quote Share this post Link to post Share on other sites
S73DOD 0 Posted October 27, 2009 i got all excited for nothing,dint turn up,b@[email protected] delivery van that rolled up i thought was for me.lol. yeah i order it with g-werks its been a month since i've ordered it, i phoned a few times beforehand an they dint have any in stock...... i hope it turns up soon,dont fancy waiting 3 months. :( Quote Share this post Link to post Share on other sites
eddy.h 0 Posted October 27, 2009 my mate had the same thing 3 months . which bit is cracked i my have 1 what part of Manchester are you form Quote Share this post Link to post Share on other sites
Richardshoes 0 Posted October 28, 2009 Hi. I have a model and manufacturing drawing. You can make your own if you can machine? Quote Share this post Link to post Share on other sites
S73DOD 0 Posted October 28, 2009 YES! it turned up this morning and i fitted it during my dinner brake, carnt believe the difference its made.the box had broke were the 2 halfs meet and had a crack on the lower bolt hole, it was fooked,went straight in the bin.im very impressed overall,iam from stalybridge you know it? thanks lads. :D Quote Share this post Link to post Share on other sites
eddy.h 0 Posted October 28, 2009 bet your wall happy yes i no stalybrigde i have a mate in mosley Quote Share this post Link to post Share on other sites
