VRSICK 0 Posted July 30, 2009 I have a leak at the drivers side, near the door (wher the feet go) and i dont know how to solve the problem :( The wierd thing is that it only happens when it's heavily rained. It doesnt happen often but i need t get it sorted. Any suggestions peeps...?? Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted July 30, 2009 Probably leaking through under the doorcard. Whip it off and check the sealing on the waterproof membrane. Try a search there's loads on here about leaks!!! Quote Share this post Link to post Share on other sites
tom n 0 Posted July 31, 2009 I have the exact same problem! Also i have noticed if you're driving through heavy rain, it doesn't get wet, only when standing still Quote Share this post Link to post Share on other sites
casual 0 Posted July 31, 2009 try the grommets in the engine bay.. there is a few leading to the footwell, 1 for acelerator cable etc. mine were missing so had to get new 1s but never had a leak in fairness. but in theory would run down into footwell. Quote Share this post Link to post Share on other sites
VRSICK 0 Posted July 31, 2009 I think my mechanic did check the engine bay and all was fine :confused4: I just dnt know where this bloody water is cummin from...!! Quote Share this post Link to post Share on other sites
casual 0 Posted August 1, 2009 get some to simulate it. spray with a hose while your inside... pull carpets up etc Quote Share this post Link to post Share on other sites
VR6 0 Posted August 1, 2009 Door card. Take it off and check the membrane is diverting water towards the door car/interior of the car. Quote Share this post Link to post Share on other sites
phil naxos 0 Posted August 2, 2009 I had the same problem with 2 of my corrados, so I have replaced the polythene bacing behind the door cards. putting the door card back is a bit of an art. Trick is to put the card over the pin of the door lock to hold it before screwing back the card. The water should stay within the door cavity and naturally drain through the holes in the bottom of the door onto a flat cill, rather than find its way through the mastic sealant holding the membrane. VW sell a grey foam liner which you cut to fit. check the rubbers next to the drop glass so there isn't a massive gap to let water in when it's standing still. Philip Quote Share this post Link to post Share on other sites
VRSICK 0 Posted August 3, 2009 Thanks peeps for all the responses. It sounds as tho its abit of a job :confused4: Quote Share this post Link to post Share on other sites
Leonard 0 Posted August 3, 2009 Thanks peeps for all the responses. It sounds as tho its abit of a job :confused4: Its not too bad mate. I am certainly no mechanic and didnt have any problems. There is a guide on here to taking the door cards off if you search Matt Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted August 3, 2009 It's just a logical sequence, nothing taxing engineering-wise!!! Quote Share this post Link to post Share on other sites
Leonard 0 Posted August 4, 2009 :cheers: You gonna give it a go then? :grin: Really good door card removal guide here: http://www.torquevw.com/how_to_guides/c ... ards.shtml Quote Share this post Link to post Share on other sites
VRSICK 0 Posted August 14, 2009 I think im just going to wait until i get a leak agen. Its not happened since iv posted this topic :) Quote Share this post Link to post Share on other sites
PROVR6 0 Posted August 14, 2009 Im no mechanic either, but removing the door card is very straightforward, just don't miss the hidden screw in the speaker hole. Ive never attempted to remove a door card on any other car, but with the corrado things like this become necessary sometimes. In a way its good as it give you more confidence about tackling different jobs. Quote Share this post Link to post Share on other sites
C. Will Corrado G60 2 0 Posted August 24, 2009 We've move the guide to here, the old one wil stay there for a while but it will to deleted at some point. New location to Corrado door card removal http://www.torquevw.com/index.php?option=com_content&view=article&id=69:corrado-removing-a-replacing-front-door-cards&catid=36:how-to-guides-corrado&Itemid=28 Quote Share this post Link to post Share on other sites
