Richardshoes 0 Posted August 1, 2009 Hi chaps. Can the clutch master cylinder be removed without taking off the brake servo on a 16V C? The mounting bolt to the bulkhead closest to the servo looks difficult to get at without the servo removed. Cheers. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 1, 2009 Yeah - should be do-able... you could loosen the servo bolts from inside the car but I'd try to do it without... I changed my Brake Master this morning - fairly straight forward and did think about doing the clutch at the same time as I replaced the pipe leading to it from the fluid res but decided to leave it for now as I had a load of other stuff to do. Quote Share this post Link to post Share on other sites
