RadoVirgin 0 Posted August 4, 2009 Hi, i'm just enquiring if anyone has any experience in fitting carbs Bike/Dellorto to a 9a 16v engine? I'd like to know if i can use the standard dizzy or will I have to employ an aftermarket system like Megajolt etc. I'm thinking of going for a full dellorto setup or possibly bike carbs. My engine is standard but I plan to fit a kr inlet cam prior to fitting the carbs. I'd appreciate any advice on the possible pitfalls and any special considerations that I might need to take into account. Cheers Quote Share this post Link to post Share on other sites
tyler 0 Posted August 4, 2009 you can run the carbs on a normal setup you might have to advance the timing slighlty but easier and cheaper than buying a mangerment system. im thinking of doing the same conversion in my mk1 runningr1 carbs :D but now thinking i might run bike injection system to be different :lol: Quote Share this post Link to post Share on other sites
bobbymkII 0 Posted August 4, 2009 if car has a cat fitted wont ever pass emissions test on carbs...unless your building track car and only for track...you will struggle to get a m.o.t august 1993 is from when it should have a cat...if ur pre august in that year ur happy days...if not..ur buggerd unless m.o.t bloke is going to stick probe up somebody else car at m.o.t Quote Share this post Link to post Share on other sites
