ricickles 0 Posted August 23, 2009 I need to wire a switch from my fuel pump to my dash for my track car. its the 16v kr basicly i was wondering if theres any diagrams on the net that shows me which is my 12v supply so i can run a switch of it. Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted August 23, 2009 http://www.a2resource.com/electrical/CE2.html Quote Share this post Link to post Share on other sites
ricickles 0 Posted August 27, 2009 i was wondering if anyone could post a pic of the back of there fusebox if possible. my fuel pump has stoped priming and this is only happend since i removed the dashboard. i only have 2 power cables coming in from the engine bay a brown and red, and know matter how i configure them they will turn the car onto ignition but theres no fuel pump prime. i belive it has something to do with ports 30 30b y z1and z2 Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted August 28, 2009 follow the link above it tell you what wire goes to where. Quote Share this post Link to post Share on other sites
ricickles 0 Posted August 28, 2009 i have done but as i said i only have 2 cables coming in that will fit onto there i belive i should have 4 or is it possible to jump the conections Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted August 28, 2009 Fing the G1 plug- pin 03 (G1/03) this is the ecu EARTH trigger wire,tap into it and fit a toggle switch and run a wire to it and the other wire direct to chassis ground and your done mate. Quote Share this post Link to post Share on other sites
