rajarella 0 Posted August 25, 2009 I'm stuck outside work in the vr and it refuses to start. This has been ongoing but this is the worst it has happened. I have checked for loose connections and found nothing. Only thing I can see is a really thin blue wire with a spade connector on the end, should this be attached? Quote Share this post Link to post Share on other sites
VR6 0 Posted August 25, 2009 Bit more information! Is it turning over? Dash lights on? Fuel pump priming? etc Quote Share this post Link to post Share on other sites
millerman 0 Posted August 25, 2009 try tapping the relays ??? Quote Share this post Link to post Share on other sites
rajarella 0 Posted August 25, 2009 Doesn't turn over, fuel pump primes and dash lights are on. I have a brand new igntion switch I have just plugged in and tried turning directly but nothing. Stupid question but where are the relays? Quote Share this post Link to post Share on other sites
millerman 0 Posted August 25, 2009 above the fuse board located just above the bonnet pull Quote Share this post Link to post Share on other sites
VR6 0 Posted August 25, 2009 Could also try fiddling with the loom that runs into the back of the ignition switch (while key is in the start position). Need to remove the surround from the steering wheel. Quote Share this post Link to post Share on other sites
rajarella 0 Posted August 25, 2009 I did that with no joy. I just managed to bump start it now so gonna get it home and have a look for the relays. Quote Share this post Link to post Share on other sites
swiftkid 1 Posted August 25, 2009 check the earths, especially the one at the front attached to the starter. put ignition on and see if it gets hot Quote Share this post Link to post Share on other sites
millerman 0 Posted August 25, 2009 check the earths, especially the one at the front attached to the starter. put ignition on and see if it gets hot good call that remember when mine went one minute it worked the next it did not and just seemed to have rusted away :( Quote Share this post Link to post Share on other sites
wippy 0 Posted August 25, 2009 sounds like you may need to recondition your starter to me Quote Share this post Link to post Share on other sites
rajarella 0 Posted August 25, 2009 Checked the earth last weekend when I reconditioned my starter so done both those things :D When I did the starter it was near perfect inside, just a slight bit of carbon build up. I didn't touch the solenoid but when I do have the problem I don't get the usual click linked to a dodgy solenoid. Quote Share this post Link to post Share on other sites
wippy 0 Posted August 26, 2009 if you dont get a click then its either the solenoid thats fauty of the feed to it, take a piece of wire with you and next time it happends connect one end to your batt + and the other end to the starter motor feed, if it does not turn the car over then you know its the starter Quote Share this post Link to post Share on other sites
rajarella 0 Posted August 26, 2009 Cool I will try that. Quote Share this post Link to post Share on other sites
mattnorgrove 0 Posted August 26, 2009 Could also be a weak battery maybe?? Quote Share this post Link to post Share on other sites
dr_mat 0 Posted August 26, 2009 Could also be a weak battery maybe?? Yes, I've had everything from the uzi-like rattle of solenoid engaging and disengaging right the way down to the total and utter silence, all caused by low battery charge. You need about 11.8 volts at the battery to start a VR. Quote Share this post Link to post Share on other sites
Reggit 0 Posted August 26, 2009 if you dont get a click then its either the solenoid thats fauty of the feed to it, take a piece of wire with you and next time it happends connect one end to your batt + and the other end to the starter motor feed, if it does not turn the car over then you know its the starter You need a thick piece of cable to do this, use a decent quality jump lead or similar gauge cable. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted August 26, 2009 if you dont get a click then its either the solenoid thats fauty of the feed to it, take a piece of wire with you and next time it happends connect one end to your batt + and the other end to the starter motor feed, if it does not turn the car over then you know its the starter You need a thick piece of cable to do this, use a decent quality jump lead or similar gauge cable. No kidding, this needs to carry close to 200 amps. Bell wire will burn through before you've had time to drop the cable, shout "christ that's hot", and jump up and down blowing on your fingers. Quote Share this post Link to post Share on other sites
rajarella 0 Posted August 26, 2009 No kidding, this needs to carry close to 200 amps. Bell wire will burn through before you've had time to drop the cable, shout "christ that's hot", and jump up and down blowing on your fingers. I am starting to think I would rather keep doing my shoulder in bump starting it!! Quote Share this post Link to post Share on other sites
dr_mat 0 Posted August 26, 2009 No kidding, this needs to carry close to 200 amps. Bell wire will burn through before you've had time to drop the cable, shout "christ that's hot", and jump up and down blowing on your fingers. I am starting to think I would rather keep doing my shoulder in bump starting it!! Heavy duty jump lead should be fine ..... :) This is of course assuming that's what the fault is. It might make no difference .. Quote Share this post Link to post Share on other sites
rajarella 0 Posted August 26, 2009 It has to be worth a try. It is getting beyond a joke. Quote Share this post Link to post Share on other sites
wippy 0 Posted August 26, 2009 if you dont get a click then its either the solenoid thats fauty of the feed to it, take a piece of wire with you and next time it happends connect one end to your batt + and the other end to the starter motor feed, if it does not turn the car over then you know its the starter You need a thick piece of cable to do this, use a decent quality jump lead or similar gauge cable. No kidding, this needs to carry close to 200 amps. Bell wire will burn through before you've had time to drop the cable, shout "christ that's hot", and jump up and down blowing on your fingers. sorry i think i worded this slightly wrong , i didnt mean the main power feed to the motor but to the solenoid, mine is around 2.5-3mm thick, if the starter works when you do this , then there is something wrong with your feed , if the starter still does not engage then you probably have a faulty solenoid/starter, sorry for the missunderstanding Quote Share this post Link to post Share on other sites
