robtalbott 0 Posted September 11, 2009 what is the normal g60 oil temp you would expect whilst left to idle? (as in if you left it idling how high should it get before it levels off?) Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 12, 2009 Hard to say actually but mine gets to around 90ish, same as the water but then I have a mocal cooler and Schrick sump... as soon as you start driving it will go up and under normal conditions hit around 98-102, after driving fast is easily climbs to 110-116 but always comes down quickly again at idle to around the 100 mark. Quote Share this post Link to post Share on other sites
robtalbott 0 Posted September 12, 2009 thanks mate, anyone know what it should be with stock fittings? Quote Share this post Link to post Share on other sites
dirtytorque 0 Posted September 12, 2009 thanks mate, anyone know what it should be with stock fittings? as above.. He's has a mocal to combat hard driving temps but I think he is running a smaller charger pulley aswell?!?? My standard G hovers around the 100-108 mark most of the time. Quote Share this post Link to post Share on other sites
robtalbott 0 Posted September 12, 2009 cool thnks, was a bit worried about the temp as its quite high but seems g60s run like that anyway! Quote Share this post Link to post Share on other sites
