parrotman1 0 Posted September 13, 2009 could someone tell me the following Info: my 91 G60 (8 valve i guess ).exhaust is blowing its got a de-cat system at present. Should it have a Lambado sensor fitted to the De-cat? Also is it a big job to replace the manifold ? Thanks Quote Share this post Link to post Share on other sites
raddo_tom 0 Posted September 13, 2009 Yes to Lambda. Yes to manifold depending on the bolt condition... Not the most room to do it either unless your dropping the engine out. Also if one bolt shears you'll be wishing you could shoot your engine with a rather large gun. Best advice I can give you is Grease WD40 and take your time.. OR give it to a garage. Quote Share this post Link to post Share on other sites
parrotman1 0 Posted September 13, 2009 Thanks for reply , better have another look for Lambada sensor then. Sounds best to stay away from manifold. Is there no easy job on G60 engines. Quote Share this post Link to post Share on other sites
raddo_tom 0 Posted September 16, 2009 erm..... No. :censored: :brickwall: Quote Share this post Link to post Share on other sites
