VRTrickster 0 Posted September 24, 2009 Should disconnecting the mass meter whilst idling effect the running as you unplug it on a OBD2 as it does on a OBD1? Im trying to figure out whether it is at fault? Cheers! Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted September 24, 2009 OBD2 should stall. In VAG-COM's measuring blocks you'll see the live Air mass measurement in grams/second. Blip the throttle and the number should rise and fall etc. If it doesn't or there's some very weird readings, the maf is probably past it's best. Quote Share this post Link to post Share on other sites
VRTrickster 0 Posted September 24, 2009 Right ok, I unplugged it earlier when I got to work and there was no change! I then fitted a spare I had and the car is running better, but Im not sure if that one isnt that great either? The problem Im getting is rough running/idle and also the revs dropping abruptly when dipping the clutch to a point where the battery light flickers, then it picks up. I may fork out for a new one tomorrow from GSF. I havnt had it on vagcom yet, Im trying to sort my laptop out, but Im sure Ill have it up and running soon. Kev what sort of readings should I be seeing for the lambda? Cheers for your help! Quote Share this post Link to post Share on other sites
millerman 0 Posted September 24, 2009 i would get it vag com.ed first b4 you start splashing money out on things you think may be wrong as it could well be something completly different i vagcomed mine this morning as i thought it was running a little off and turns out the blue temp sender is buggered i though it was the maf or a breather pipe ! Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted September 29, 2009 Right ok, I unplugged it earlier when I got to work and there was no change! I then fitted a spare I had and the car is running better, but Im not sure if that one isnt that great either? The problem Im getting is rough running/idle and also the revs dropping abruptly when dipping the clutch to a point where the battery light flickers, then it picks up. I may fork out for a new one tomorrow from GSF. I havnt had it on vagcom yet, Im trying to sort my laptop out, but Im sure Ill have it up and running soon. Kev what sort of readings should I be seeing for the lambda? Cheers for your help! Interesting. My OBD2 would stall out immediately if I plugged in a MAF it didn't like. Perhaps your ECU already bypassed it. I can't remember the exact readings but something like 5g/s at idle rings a bell, and increases as you open the throttle. Should also be 1V on the MAF signal line at idle. Be careful with GSF mafs, I've had a couple of DOA ones from them before. In fact I don't buy anything from GSF anymore if I can help it. Quote Share this post Link to post Share on other sites
VRTrickster 0 Posted October 5, 2009 Right well I finally got vagcom hooked up and the maf seemed to be doing as you said, 4.5 to 5 then raising with the throttle. It did have a G62 implausible signal, intermittent fault. I replaced the sensor with one from ECP, cleared the codes, and took it for a spin. On my return it had brought up the same code again! I know it could be a faulty connection. I checked the connector and it looked fine except one of the contacts was slightly discoloured. Should I replace the connectors or could it be a faulty new switch? :? Quote Share this post Link to post Share on other sites
