ken corrado
wireing looms easy to change?
dash loom has melted, i got some cheap fuses that didn't work
i dont no how much damage has been caused but there was a lot of smoke from behind the dash and from what i can see there is a lot of meltid wires behind the light switch.
When my light switch went wrong,that caused a mini fire !
took a lot of time to sort out all the issues it caused !
the light switches are very well known on here,most likeley that ,then your cheap fuses
Your H reg is an early car and the L reg is a late car. Looms will be different. Changeover year was '92.
Headlight switch has it's own loom.
ABS (if fitted) has its own loom.
Fogs & HRW share the same loom.
Clocks have their own loom. I think they are different between analouge and digital clocks.
All can be replaced easily enough without having to take the dash out.
Chances are it's just the headlight loom that's gone. Caused by your headlight switch and cheaps fuses not liking each other.
