dom911 0 Posted October 16, 2009 as above need to remove the ecu whats the best way to do this,have had a look but can't see how to get it out,don't want to brake anything so any help would be great. Quote Share this post Link to post Share on other sites
millerman 0 Posted October 16, 2009 need to move the scuttle cover back on the left hand side then that reveals a 10mm nut which you need to undo then disconnect the wiring loom then push the ecu towards the fan air intake to unclip it from the rest of the retaining clips then wiggle out its very tight (oohh er missus) :D hope this helps Quote Share this post Link to post Share on other sites
dom911 0 Posted October 16, 2009 need to move the scuttle cover back on the left hand side then that reveals a 10mm nut which you need to undo then disconnect the wiring loom then push the ecu towards the fan air intake to unclip it from the rest of the retaining clips then wiggle out its very tight (oohh er missus) :D hope this helps Thanks will have ago 2mora. Quote Share this post Link to post Share on other sites
