radojunkie
recently fitted 1.9 engine and sick gbox couple of runnin qs
i have a stainless stell 4-2-1 exhaust manifold, but when after 5mins of running its glowing red hot is this normal? also just got oe heatwrap on chassis will this withhold the temp?
next question is what should the timing be and fuel/air mixture for this particular spec:
ngine:
stage 4 charger
Jabbasport fully Rebuilt 1.9 Bottom End
Je low compression Pistons
9A 16v Rods
Later crank Fitted
New Oil Pump Bearings and Seals
Lightened Flywheel
Fully Balanced Bottom End
TSR pack C Big Valve Head
Piper 285 Cams Shaft
Polished Rocker Cover and Head
Sachs vr6 clutch
red top injectors
sns chip
gear box:
1st,2nd,3rd + reverse vr6 gearing and limited slip diff - stealth racing
Breathing:
custom front valance
custom cosworth intercooler
custom 3" pipework
mocal 16 row oil cooler
+ thermostatic sandwhich
tsr flowed manifold
stainless 4-2-1 exhaust manifold
decat full miltek exhaust system
any ideas???
