LukeManic 0 Posted October 24, 2009 Hi all, I'm experiencing a grinding/rubbing noise coming from the passenger front wheel once the brakes have been used for about 10mins or so (depending how much braking has been done). If I go very slow on a quiet road I can hear the noise without braking and then if I slighly apply the brakes the noise gets louder. It sounds to me as if the pad or disc is expanding with the heat and causing them to rub?? Has anyone else experienced this and found a solution? The pads and discs aren't that old and as I say, its only coming from the passenger front wheel. Any advice is greatly recieved. Cheers, Luke. Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted October 24, 2009 try swaping your wheels over as it sounds like tyre noise,if no better possible wheel bearing. Quote Share this post Link to post Share on other sites
