pt_corrado
BBm fuel rail 8v g60
hello guys, another question for all of you.
Its easy to fit these fuel rail in the G60?
It will notice some kind of diffrence with this?
can you post some photos of the rail mounted in a corrado g60? try to search in the forum but cant find any car with this part mounted.
Hope you guys can help me.
best regards :salute:
won't make any difference to how your car performs.
To remove stock rail just remove ISV and rocker cover for better access.
Then remove fuel injector wiring,fpr and fuel lines etc.
Make sure there is obviously no fuel pressure in the system before disconnecting fuel lines.
It doesn't get as hot as the normal rail but the feed pipe has to be longer and across the top so defeats the point really...
You also loose the fuel pressure after-run switch.
humm, i already take off the OEM one, but i´m not seeing very well how the "new" one will fit as i dont have yet the BBM one.
thanks for the help guys :notworthy:
