delfinis38
Tappets ??? maybe...
If i havent started the VR for a while (I'm talking 3-4 months), she quite often sounds tappety until the engine has warmed up to about 100 degree's. after she's warm she purr's like normal. It only happens if she not been started / left for a long time. Is it Anything to worry about or is it normal as the engine has not be lubricated for a while.
I know the solution is to use her more! i try to get in the habit to start her every few weeks but sometimes it never happens.
thanks for the reply.... intend to do an oil change in the next few week's in prep for winter. normally use 10w40 quantum gold stuff i think ( i buy it from my VAG dealer). but need to check in the gargage. what do you guys recommend.
if you fancy changing your oil pump at the same time as your oil change i've got one with 150miles on it for sale. :) this will usually eliminate lifter noise as well especially if the old pump has seen a lot of distance and has become worn
Chris
