krnau
KR Fuel pipes that should be replaced
Hi. I read many posts about g60 fuel pipes cracking and setting the car on fire. I went to the stealer and bought two fuel pipes for my KR which are made of rubber. they costed ~30€ each and I only wanted to let you know that it would be good to replace them. These fuel pipes are the ones that go from (your) driver's side of the engine bay, to the metering head. They are the only 2 (I think) that are not made of metal.
part numbers are:
051.133.699C
051.133.723C
I will be replacing them next week. I will let you know the condition that the old ones were in.
I removed both of them, and I found that one bolt had a "filter" in it which might be worth checking in the process. mine was very clean btw.
hope it helps :)
