jamiehol 0 Posted November 8, 2009 Got an annoying fault with my VR6 It started out as an intermittent non starting fault in the summer, where it will crank over and the fuel pump relay will click, and will now just not start full stop. I will crank over and you can just hear the fuel pump relay clicking It an attempt to fix the intermittent issue it has had it has had the following. - New Fuel Pump Realy - ECU Realy - Ignition swithc swapped for a known working. Does anyone have any suggestions wht to try next or anyone had a similar porblem. Thanks Jamie. Share this post Link to post Share on other sites
VR6 0 Posted November 8, 2009 Can we stick to an existing thread please Jamie? viewtopic.php?f=1&t=83801 Cheers Share this post Link to post Share on other sites
jamiehol 0 Posted November 8, 2009 Sorry about that, forgot about my post when the problem originally started and hadn't seen half the replies as I am not always on here. Share this post Link to post Share on other sites
