ShabC 0 Posted November 15, 2009 yestheday i was driving back from work, i though i put my foot down i got up to 3 and half thousands revs then it just felt like i lost power and it would't go any higher above 3 and half then one of the belts started to squeke very bady whats going on, rung jabba they think its a boost leak some where? i had the charger rebuilt in june! the car is standed only boost delet kit fitted. what could it be timming belt? or power stireeing belt or is the chrger just f**ked help please. andy Quote Share this post Link to post Share on other sites
dirtytorque 0 Posted November 15, 2009 was a squeak or more of a whistle noise? Is the throttle bleed screw on the back of the throttle body still there? Is the bottom crank pulley on securely? Check all your boost hoses. Quote Share this post Link to post Share on other sites
ShabC 0 Posted November 16, 2009 more of a whistle noise. andy Quote Share this post Link to post Share on other sites
DanVW 0 Posted November 16, 2009 sounds like clasic loose crank bolt to me, check your timing marks are all still lined up. Quote Share this post Link to post Share on other sites
dirtytorque 0 Posted November 16, 2009 maybe but if it is whistling I rekon it's the bleed screw which has popped out from the back of the throttle body. Quote Share this post Link to post Share on other sites
