funky
chip & pully
HI ALL
ive seen an ad in the golf for a g6o tuning kit includes chip 70 mm
pulley and wider belt from supergolf imports says 190 bhp butt its
only £120 can this be any good? seems too cheap has any one got this
or know anything about it ?
cheers in advance
funky g60
Probably a generic chip. 70mm pulley? pah :roll:
Why not give the man a call and find out exactly what its about. Cant do any harm?
70mm pully doesn't make any sense. wouldn't that make the chargers spin slower?? Kinda defeats the purpose does :? n't it?
there are so many different types of chip jabba,etc whos got what and how do they rate them i dont wanna buy something ill not be happy with and then find out i could have got a better one
cheers funky
is standard not 78mm?
you want a 68mm aluminium pulley and SNS chip from Pitstop...180 quid
Got mine done last week and cars a new beast altogether.
Reckon the word of SNS is spreading quicky...see loads of posts about people switching from jabba over to them now
Done 350miles now :)
All most there..will take it easy for a bit tho.
I have noticed car smeels of petrol until warmed and driven a bit harder.
I haven't adjusted the timing yet tho so will have to sort that out when its run in. I was thinking it would need advanced as its running rich ??
Power etc seems good...I always run on optimax to. Any ideas?
Petrol?? You shouldn't be smelling petrol. Check the fuel lines to your new FPR, there might be a leak. :shock:
The car runs stoich under normal driving, its only when the ecu switches to open loop (map) when your fuelling will increase to compliment the boost. :D
