GREENY
ELECTRIC WINDOWS
My elecric windows have packed up, ive checked the fuse and its ok and also if i put a direct live to the motors it goes up and down so ive ruled out them.
Any ideas????
one more thing, remove the door card and inspect the loom into the body, as sometimes the wiring will chaff and create an open circuit, where the rubber boot goes into the car, remove and inspect, hope this helps/
Try the windows with the drivers door open - if they work from the drivers sw with open door it's fuse 16 IIRC, weird wiring set-up sorry if you've tried this already!!
If this is the case I have two early door looms for sale...
