VRTrickster
312mm brakes flexis?
I was just wondering how people have run their flexis from the calliper to the solid line?
I was thinking of cutting the original grommet with a stanley blade and putting it around my goodridges then pushing it into the normal flexi bracket.
What have you guys done with yours?
Cheers!
The grommet should stretch over the brake line easily enough. That is if I you are talking about the grommet which secures the flexible hose to the strut?
Yes I am, oh. Ive already cut one side as it looked as though it would have been a pain to take off. Ill have a go at removing the other side. I dont think the one Ive cut will go anywhere as its quite tight in the bracket.
Cheers!
