steveh
Stub Axle Bolt Torque Settings
Hi
Can anyone tell me what the bolts that hold the stub axle on are supposed to be torqued to?
Saw the item in knowledge base but it didnt really tell me what the stub axle bolts should set to.
Thanks in advance.
Steve
are you talking about the bearing bolt or what holds the stub axle on ? if stub axle just tighten till you can get no more , or if bearing just do up till there is no play in the wheel
