bigdogolly 0 Posted December 23, 2009 Hi All. I have just bought a corrado g60 and when a put my foot down it coughs and seems like its clogged up. If you just ease the revs on then it seems ok. I thought it might be the leads or plugs but not replaced them as of yet. Has anyone had the same symptoms, if so what do you recommend Thanks peeps Quote Share this post Link to post Share on other sites
MattWilde 10 Posted December 24, 2009 Welcome to the forum :wave: Have a little search of your symptoms (over fuelling G60) and I'm certain there'll be lots of info for you. The blue temp sender is normally the first culprit to change then you work your way through the ignition system and earth leads. Good luck Quote Share this post Link to post Share on other sites
