MattG60
oil filter problem help needed
hi ive got a problem with my corrado g60. the rubber seal on the oil filter keeps popping out dumping all my oil on the floor. ive been told it is a block in the breather pipes, hich causes an increase in pressure and it is finding a way out through the filter. but I cant see why it would come out of the filter, when the weakest point would surely be the dipstick??!!
all help is much appreciated
I doubt it would be from a blocked breather, sounds more like you have an oil pressure problem, i would get the pressure checked by someone with the necessary equipment.
