Topaz2008
G60 Temperature Sensor Housing
I have a leak coming from where the black plastic sensor housing joins the head :( . I removed this and the O ring seal is flat so I purchased a new one form VW this morning and replaced it :D . The problem is I still have a leak from this flange under pressure :censored: . I am sure I should have used some sealant on the joint but am not sure what to use.
Any ideas?
The plastic flanges warp with age so the O ring is not enough - really best to replace the lot - bolts, sensors, clips etc
No sealant needed unless the face of the cylinder head is badly corroded.
