lil b
Engine temp questions?? Advice needed
Hello,
I have a few question I need answering RE: my 2L 8V corrado...
1 - On the on board computer, for example it will read between 90º and 100º - yet the temp gauge reads between 70º and 80º.... am I being completely blonde, are these for the same reading? or is one oil and one water? :cuckoo:
2 - On constant driving the temp gauge hovers 70-80.. is this correct? So what I'm trying to explain is in traffic it comes to 85+ then goes back down, is this correct??
3 - the Digital gauge can go upto 102 in traffic sitting then hovers around 94.... is this correct??
If these are too high what can I do to correct the problem?? different strength/tolerance thermostat???
Again sorry I do not know the correct terminology and I am trying my best to sort my car out :D (full service soon :clap: )
Thankyou very muchly
Becki xx :scratch:
  lil b said:
Hello,
Becki xx :scratch:
MFA shows oil temp which is higher than water
70 to 80 in winter is ok - 90 to 95 should see fan cutting in to cool down
oil will get hotter when you come to a stop from a run as the ambient temp of the engine is still high
all sounds good - run car upto temp then leave ticking over to check rad fan is working - watch the temp guage just in case if it hits 100 shut her off and investigate.
  Quote
Brilliant thanks!! - takes a weight off my mind.
Becki x
The needle gauge is the water and the MFA is the oil.
When dbug says watch the gauge to see if it hits 100.. i think he means the water gauge rather then the oil gauge.
may wee mon sure :grin:
