carrots 1 Posted January 31, 2010 hi all,ive got a prob with my indicator light on dash.it stays on even when the indicators arnt on.only dim tho :help: Quote Share this post Link to post Share on other sites
dbug 0 Posted January 31, 2010 i've got this too, does yours go off completely when they flash ( eg using the indicators ) i am guessing initially that it is an earth issue OR something to do with the various alarms that have been fitted to it in the past. with mine going off completely when they flash i am guessing its not the relay but who knows. i am starting with the relay then earths in the front lights then the repeaters the rears will be the last ones to check as they are away from the elements. . . . let us know if you find it. Quote Share this post Link to post Share on other sites
carrots 1 Posted January 31, 2010 ive changed the relay,changed the indicator stalks because they where dodgey.the light seems fine when i indicate.could be an earth,i was thinking of the plug in back of speedo Quote Share this post Link to post Share on other sites
dbug 0 Posted January 31, 2010 ??bad earth in clocks?? could it be as simple as that ??- was waiting till better weather to investigate mine. big believer in if it works then leave it till you can do without it ( too many old vw's over the years ) :lol: Quote Share this post Link to post Share on other sites
carrots 1 Posted January 31, 2010 ive got plenty of jobs to do to mine when the weathers beter.roll on the summer :D Quote Share this post Link to post Share on other sites
krnau 0 Posted February 22, 2010 it's 99% probable that there is a split/cut wire in the clocks harness. this wire is the one that takes the signal to the indicator green led light in the clocks. I found the easiest way was to remove that led :lol: :lol: as a temporary fix (temporary fix = lifetime fix :nuts: ) Quote Share this post Link to post Share on other sites
