theblueflash 0 Posted January 31, 2010 i cant seem to find a topic on replacing the heater blower motor. mine squaks like a good un and id like to take it out and either service it or replace it. many thanks Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 31, 2010 Non air con I assume? Just remove the lower passenger shelf - 4 screws I think The you will see the motor, unplug the 5 pin connector to the resister pack The motor kind of clips into a bayonet fitting so take note of orrientation There is a plastic locking tab on the right as you look at it, use a torch to see. Screwdriver maybe to release it as you turn the unit. Then resistor pack just unclips at the bottom with the 2 wires. Quote Share this post Link to post Share on other sites
davidwort 0 Posted February 1, 2010 ... There is a plastic locking tab on the right as you look at it, use a torch to see. first time I tried to remove one of these on a Passat it took me half an hour of hacking at the plastic enclosure, felt majorly stupid when I found the plastic tab, lift tab twist and it just drops out in 2 secs :epicfail: Quote Share this post Link to post Share on other sites
theblueflash 0 Posted February 1, 2010 cheers. will prob get round to that this week. found a valver in a scrappy near me so may strip some bits off that inc. the blower if she's knackered. thanks for the advice :D Quote Share this post Link to post Share on other sites
Novastrike 0 Posted February 2, 2010 Hi Blue, If it has a cream interior (wishful thinking, i know!) could you let me know! Thanks Quote Share this post Link to post Share on other sites
dragon green 5 Posted February 2, 2010 Heres a link, wiyh a lot of pics - http://website.lineone.net/~quigger/heater.htm Quote Share this post Link to post Share on other sites
