quicky1980 0 Posted February 1, 2010 I have a late r32/audi 3.2 engine that has just one fuel supply line on the fuel rail. I presume the audi/r32 pump has a built in fuel pressure regulator, if so can I fit the audi pump to my corrado or is this just not compatable? This would allow me to ditch the vr's return line. cheers Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted February 1, 2010 Far cheaper and easier to use a 3 port fuel regulator. Quote Share this post Link to post Share on other sites
quicky1980 0 Posted February 1, 2010 Far cheaper and easier to use a 3 port fuel regulator. Is it? Looking at prices of fpr it not cheap, circa £130. Just wondered if the r32/audi fuel pump fitted or is it more involved? You know of any good fpr? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted February 1, 2010 You just need an FSE regulator, 1:1, 3 port, they're about £65. You don't need an expensive SX or Aeromotive one for normally aspirated, or Herisites used an Aeromotive Chinese copy from ebay, which cost him about £50 I think. I have no idea about using the R32/Audi fuel pump setup. No one else seems to do that so I gather it's not an easy or cheap thing to do, otherwise it would be used in preference to a 3 port reg. And personally speaking, the Corrado's fuel tank and fuel delivery system works perfectly, so no point messing with it imo :D Quote Share this post Link to post Share on other sites
quicky1980 0 Posted April 14, 2010 The connections that come with the fpr are naff, any idea where I can get some fuel connectors that thread into the fpr and have a simple fule line spout on the other end that allow the hose to be jubileed? Quote Share this post Link to post Share on other sites
