warren 0 Posted February 1, 2010 HI ALL, i have just noticed after the last couple of days, a very annoying squeak coming from the brakes when reversing. This is without touching the brake pedal, when slowing down or braking in normal driving conditions, there is also a very slight squeak, but not as loud as in reverse :confused4: any ideas? Quote Share this post Link to post Share on other sites
mimjed 0 Posted February 1, 2010 lots of people seem to find this, but seemeingly no real problem/solution has been found. good clean down and grease to start with see if it helps at all. Quote Share this post Link to post Share on other sites
warren 0 Posted February 1, 2010 oh is it a common problem? even while just reversing normally? ok mate i think i will start with a clean up and grease then :D cheers mate!! Quote Share this post Link to post Share on other sites
carrots 1 Posted February 1, 2010 could be your caliper sticking or a handbrake cable Quote Share this post Link to post Share on other sites
warren 0 Posted February 1, 2010 cheers mate, yeah another possibilitie? Quote Share this post Link to post Share on other sites
mimjed 0 Posted February 1, 2010 Not massivly common but has come up a few times. Play in bearings. Warped discs. Buckled wheel. Cv joints etc Quote Share this post Link to post Share on other sites
jonny-5 0 Posted February 1, 2010 Maybe try regriding a chamfer on the leading and trailing edges of the pad - helps with lots of seeming incurable brake squeaks Quote Share this post Link to post Share on other sites
VR6 0 Posted February 1, 2010 PLEASE stop starting threads in General. Just about every thread you've created has had to be moved from General into the correct forums. Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted February 1, 2010 I've had this too - glad im not the only one! pheeew! i get it just braking gently when in reverse, its not a quiet squeak either, its the most horrendous squeak! It sounds bad! Must be the cold. Quote Share this post Link to post Share on other sites
