farrantino
Clutch
I change my clutch slave cylinder on sunday as the old one was knackered. But now the biting point is right at the top, as before the change is was in the middle (sometimes :) ), Is the any adjustment on the clutch.
Its a 2.0 16v 1992
Thanks in advance for the advice :notworthy:
Strange one - there is no adjustment being hydraulic so this would usually indicate a worn clutch...
I would check the part you fitted was correct and maybe re-bleed though.
