Rappa KNOTZ
Charging problem...
Ok I got my battery and altenator tested and they both are good...but my battery goes dead after I drive for a little bit, what would cause this to happen....Faulty wire maybe?...Well if anyone knows what this could be please help me out!!
sounds like you have a bad earth somewhere and its draining the batterey.
does the car just die when your driving it?
when i had a 16V, it just started to die, ended up being the dizzy, had to get a new which was about £80. stuck it on and it was bang on again.
well unless it already went dead it will go dead either when driving or when its just idleing, and it didn't do this until my RPM/Fuel/Temp Gagues stopped working (I still haven't figured out why they stopped cause my fuses are fine) Maybe it has something to do with it cause i remember reading that behind the dash gauges there is a Voltage regulator and it goes out causing them to not work...could that cause the charging problem? and by the way whats a "Dizzy"?
your clock set sounds like it may be bust, not sure bout this "voltage regulator" but i would be havin a look if its got something to do with volts.
distributer aka dizzy
