Thom
Brake Caliper Pistons-Audi
Hi, yep I know I should be on an Audi forum for this, but thought I'd start closer to home.
Have done a search and nothing's telling me anything I don't know already.
Spent this afternoon changing the discs and pads on my g/fs Audi A3, put having a pig of a job winding in the caliper pistons to fit the new pads.
I have a tool to connect a ratchet to the piston and am turning it clockwise and pushing but the piston just turns (without retracting).
Have also attatched a bleed pipe to the outlet to reduce resistance put not having much success with that either.
Only asking as I understand VWs work the same way and hoping someone can help.
Cheers
Rear calipers I presume? Do they have manual or electric handbrake mechanisms? On the later cars you have to have VAG-COM to electronically retract the pistons.
If they're manual then they should just wind back in like VW calipers do.
